RCU Forums - View Single Post - Big-List of problems w/G3
Old 01-15-2005 | 06:50 PM
Razmo's Avatar
Razmo
Default RE: Big-List of problems w/G3
Thought mine may be useful aswell...
I still find the planes have too much tendency to snap though, don't you.
Yes I do..
I have had the graphics and physics set to highest since day one.
Me to..
I have downloaded an installed the Heli update.
Me to. Since the day I purchased G3
Problems:
1. Everytime I open G3 it will open at 1600 x 1200 (16bit) after I've changed the setting to my needs. This is getting very old.
2. I noticed the poor ground handeling on several of the airplanes right away. The F-16 is terrible. I have all add-ons.
3. The unrealistic stalling is still there. Yes the physics are set to their highest.
4. Several of the airplanes will gain rediculous altidude even if the flaps are all the way up and the elevator trim is all the down (forward) Luckily the trim % can be altered within the software radio to correct this problem. Yes I have calibrated my TX.
5. When flying low, the ground is difficult to make out at times unlike G2 which leads to unnecessary crashes.
6. The Yak (3d) seems to 3D like crap to me. I need to hold full
right aileron while TRYING to maintain vertical for seconds before it snaps out. The Yak (with gyro) is crap also.
7. G3 needs a ground friction setting, even though some Jets are equipped with brakes.
8. After a crash, noticibly on the Dominion 90, alot of the time it the nav guide reads a bunch of junk values and it locks up showing the heli at zoom upon a blue screen. This is getting old as well because the only way I have found to break out of this BUG is to close out and reopen G3. I then of course have to reset the resolution to 1024 x768 (32bit) everytime.
So far, I will say the graphics are pretty sweet, much better than G2. I'm running a Nvida 6800 on a 19" Trinitron CRT with Antialiasing settings to max. But I'm very dissapointed with the above. The heli update may have cured a % of the problems but they are still apparent. Please, let's get these issues corrected.
Raz
