Moki break-in
Hey:
Try removing the Cline system until the engine is thoroughly broken in. The tendency to die is probably due to over-heating, also be sure to use an OS type "F" plug --- try richening the idle disk slightly --- try adding a few extra ounces castor oil to your fuel
Hope this helps; however the Moki 135 carb has been known to give problems !
