pull start and gears
Hello cen,
I have a couple of questions for you. I have a genesis 3rd generation that I have been running for about a month. First question, my pull start kept slipping so I took off the back plate on the engine and found that the small pin with spring was recesed in the crank shaft not allowing the pull start to catch in the groove. Is this covered by waranty and how should I go about taking care of this problem? Second question, There are screws that hold on the spur gears and one of them came loose causing my pinion gears to totally strip. Where do I get these screws?
Thanks for your help
Jay Duncan
Arizona
