RCU Forums - View Single Post - R/C Nobler Topflite Gold Edition
Old 01-17-2005 | 07:07 PM
jimcork1
Default RE: R/C Nobler Topflite Gold Edition
Ok Pics will be included. I have the retract servo installed and they work. I had to move the throttle servo to the rear to clear the retract servo bolts. You will see in the pic. The top sheeting on the wing was left off for the photo. I have done a quick cg check and will have to have the battery as shown on the plans. Keep in mind I put 2 servos in the tail as / per big bird. This took out the wood beam mounts, push rods and supports. My plan was the removal of excess plus lightning holes would lighten the tail to compensate for the servos in the tail. Preliminary looks like it is working out. Got to run,, wifey calling.
ID:	216671   Click image for larger version
ID:	216672   Click image for larger version
