Wing is =.5 thrust is 0 and stab is adjusted if elevator trim is required. After that i trim as required to achieve a hands off upline under full power for the length of the current patterns tallest manuever. That is done with the thrust, which is normally not much.
Chip
ORIGINAL: tph1
What are your typical set ponts for a pattern plane , single wing like your Hydeaway? Do you put right and down on the motor? Have wing or stab at 0* and the other positive?
thanks, Tom
