Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - 3D & Aerobatic
 Incidence and thrust for pattern? >
Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Old 01-16-2005 | 06:35 AM
My Feedback: (12)
Default Incidence and thrust for pattern?
What are your typical set ponts for a pattern plane , single wing like your Hydeaway? Do you put right and down on the motor? Have wing or stab at 0* and the other positive?
thanks, Tom
Old 01-18-2005 | 12:22 AM
My Feedback: (8)
Default RE: Incidence and thrust for pattern?
Wing is =.5 thrust is 0 and stab is adjusted if elevator trim is required. After that i trim as required to achieve a hands off upline under full power for the length of the current patterns tallest manuever. That is done with the thrust, which is normally not much.
Chip
ORIGINAL: tph1
thanks, Tom
