RCU Forums - View Single Post - World Models ARTF !!!!!!!
Old 01-18-2005 | 01:40 AM
  #43
forestroke's Avatar
forestroke
Default RE: World Models ARTF !!!!!!!
Well... I had the WM Cap in Breitling colors and that was absolutely a solid performer. I installed a 46FX sidewinder in the nose and never had any problems with it. The original Cap was not, and I doubt it currently is, a 3D machine. Although there is ample area and throw in the tail feathers, the ailerons are set up really for acrobatic flying. In that it is rock solid and true... it can do pattern flying with the best of them. I had a friend that was on his 4th. If he ever had any accidents, he would simply pick up another one... it was that good! I think he has 2 wings now :-) If the new 46R builds or flies like the original... it should be a great choice. Furthermore, the hardest part of the original was putting on those countless diamond stickers... now that the pattern is already painted on the plane, it should even be easier to build.
If you've never built a WM particularly something like the Cap, I recommend you give it a try... not just plane, but the also the company!
