RCU Forums - View Single Post - Tap for glow plug threads
Old 01-18-2005 | 04:55 PM
Rodney
Default RE: Tap for glow plug threads
CAUTION: if you use the tap with the head on the engine, you run the risk of getting metal particles inside the engine. When you then run it, you may do lots of damage. The safest way is to remove the head from the block; if you do not remove the head then really REALLY really flush it out good before firing up the engine.
