RE: Avistar Servo Problems
If you are beginning stuck to the throws in the book...my friend has his way maxed out...way too hard to control for a beginner. If you feel comfortable with the sensitivity the way they are, stick with it...of coarse after flying it. If you feel you want a little more control, push the pushrod farther out on the servo arm, or closer in on the control horn.
Hope this helps
Jared
