RCU Forums - View Single Post - 3D Hell Raiser
Old 01-19-2005 | 09:48 AM
  #98
FallingWithStyle's Avatar
FallingWithStyle
Default RE: 3D Hell Raiser
What do you mean the cg is way off using the 1320 battery? I'm using a TP 1350 battery and the cg is adjustable between 3 and 3.5" just as described in the manual without having to move the battery through any bulkheads.
Unless you mean that recommended cg range is non-optimal. It does take a lot of down elevator to hold level inverted flight. Has anyone found a cg spot that balances the plane upright and inverted with no elevator input? (I've been waiting for this answer in my own thread for days now...)
Clark
