RE: SUPER SNIPER
Jetsetter,
Painting the Ultracoat if actually very easy to do and takes little prep. Some light sanding followed by tacking the surface is all that is needed. Mind you that only the wing and horizontal stab are covered in Ultracoat. The fiberglass fuselage has a slick white epoxy finish.
The mega 2T is a great motor for the combo. Mine pulled 45amps WOT and dropped to @42amps after a few seconds. Speed is probably 80-95mph for this model.
Hope this helps,
Carl
