RE: 3D Hell Raiser
Where are your receiver and ESC? My esc is in the compartment above the wing saddle and my receiver is the compartment aft of the wing saddle. If your components are farther forward, you could have trouble getting the cg back to 3.5".
Oh, did you use tail servos that are significantly lighter than the recommended HS-55s? I used HS-56's which are just slightly heavier...
Clark
