RCU Forums - View Single Post - ModelTech Dragon Lady 60 ARF
Old 01-20-2005 | 07:58 AM
2mistakeshigh
Default ModelTech Dragon Lady 60 ARF
I am building a Dragon Lady 60 ARF and have installed a Super Tiger G90 horizontally. I have used the supplied spacer and positioned the engine 5 7/8" from the firewall (Not spacer) to the thrust washer. Everything seems to be correct but when looking at the cowling when fitting it over the engine, it seems like the cowling is not going to be long enough to attach it to the fuselage.
I understand that there is not allot of overlap required but how much should there be given the setup I have described above.
Also, has anyone used this set up (A/C and Engine)? Any pictures of the assembly would be appreciated along with any tips during the build.
Thank you,
John
