RCU Forums - View Single Post - R/C Nobler Topflite Gold Edition
Old 01-20-2005 | 09:57 AM
  #32
Davesplace80
Default RE: R/C Nobler Topflite Gold Edition
Thanks for the info. I was concerned with the trailing edges not being flat when the wing is standing on them. What I did was cut away some of the trailing edge at the root ribs and move the root ribs into place. Now I am in the process of making small wedges for the leading edge of the root ribs to make everything line up as it should. This will make the trailing edge at 90deg with the root ribs. It really wasn't as much trouble as I thought it was going to be. I be glassing the center section that doesn't have the sheeting through both wings, as I learned that from having a wing fold that wasn't glassed. :-)
