RCU Forums - View Single Post - Drift Tips
Thread: Drift Tips
Old 01-20-2005 | 09:28 PM
GMdrifter
Default RE: Drift Tips
first of all you need an All wheel drive car to drift. It is extremely difficult to drift with rearwheel drive because you just spin out all the time. basicly any car can drift with the right equipment. If you have a touring car with 26 mm wheels then you need to find some 2" abs or pvc for the wheels. If they're not 24 or 26 mm then you'll have to bring them with you to your local hardware store and size em up. The store will cut them for you too. ABS is preffered because it is black in color and is a spfter compound so it gets a little more grip and is less harsh on the suspension. Once you get the ABS rings you should round off the edges with a file or grinder then glue them to a spare set of wheels. If they fit tight then you might not need glue. Now you're ready to drift.
-Remember when you are out there driftig for the first time use a big open space as you may not have very good control.
-Always remember to be very light on the throttle.
- remember to counter steer slightly once your in the drift to keep from spinning out.
-GOOD LUCK!
