RCU Forums - View Single Post - Which Engine would you choose?
Old 09-04-2002 | 01:11 AM
jimlang
My Feedback: (9)
Default Which Engine would you choose?
I have a Ohio R/C Giles 300. Thinking of using a Moki 2.1 for the engine. I would like to use a lighter engine, but will it pull out of a hover?
Here is the plane info:
Wing span: 76”
Wing area: 1100 sq in.
Weight (with Moki): just under 15 pounds (including fuel)
The Moki 1.8 is only 4 oz lighter, but the OS 1.60 weights about a pound less. How is the throttle response of the Moki?
Wing loading with the Moki will be about 31 oz/sq ft. With the OS, 29 oz/sq ft.
What engine would you use to get 3-D performance from this plane?
Thanks for the help,
Jim
