RCU Forums - View Single Post - Can Monokote be painted?
Old 09-05-2002 | 12:47 PM
gambleb
Default Can Monokote be painted?
I picked the wrong two colors for my trainer after I crashed it, Light pearl Blue and Pearl white. It was real pretty, but you can't see it in the air. I decided rather than recover I would just repaint. I used the luster-cote dark red over the blue, and with a light clear coat it turned out beautifully. Just make sure you go over the monocoat wit some 400 grit and then clean it off with rubbing alcohol should turn out pretty good for you.
Brian
