RE: Motor cuts out at half throttle. (Phoenix 25 controller)
I am programming with the transmitter. I believe I am programming it properly because I successfully changed the prop brake setting which I can verify by running the motor. I guess in answer to your question, I am as sure as I can be that I have set properly. I followed the instructions as precisely as I humanly can.
I don’t know what a servo driver is. I have the ESC plugged into channel 3 on the receiver.
