RCU Forums - View Single Post - Praise the Knife!
Old 09-14-2002 | 03:34 PM
Culverson's Avatar
Culverson
My Feedback: (14)
Default Praise the Knife!
I have owned pretty much everything Morris made except the twin and the bigger stuff as of late. He designed a very good plane, but still do not overlook the Sig Fazer. If set-up correctly the planes will do things not even in the book yet. I run either a Rossi or Heli 46 in mine again. I took my other 46 heli motor out and put it in my Ergo 46, but my new engine just arrived today OS 50 heli. Pretty much same case as the 46 and with right supports for the tailfeather flutter is not an issue. I used baking soda and thin CA to adhere thick gauge wire in all areas of the tailfeathers, it doesn't use the wire system like the Morris kits. But actually I like both systems. Morris build some good ones, and the Fazer has good lines as well. It would hover easily with the 46 with just a touch offset with engine torque. The OS 32 heli is a screamer too with a header & tuned pipe as well. This is my 6 th Fazer. The only one that was crashed was when I tried to go between two trees at a new field I got one wingtip busted slightly. I shortened each wing by 1" and the plane flew just as good as before just a lil more touchier landing was all. Morris & Sig makes great planes. I want to try the CG 330 next profile. Gotta love those Profile FF's..
