RE: Picco 21 Comp
yep - well worth the money! I have one and am very happy with it. It does take a while for it to heat up - but when it does - it screams. If you are as good a driver as the others - then you should loose nothing to them - - I am learning that the driver is a good 80% of winning - not the most expensive or fastest engine. It is the guy that runs with smooth lines and in control.
