your turning into a Helli junky i know because i did my first loop around 45 days ago on my rappy 30 and it was ugggggly!!!! I was in hover mode about 3 mistakes high had about 20 mph forward flight and pulled back on the stick. When I went inverted i got scared and pulled my collective to idle it slowed my rotation and almost stalled my blades it finally came around and the rotor heat started to pick up due to about 4 degrees of negative pitch i then gunned the throttle and recovered it looked like a cursive L after the shakes let up the smile started I don't back off so much on the throttle these days and stunt 1 oooohhh it will be your friend soon enough CONGRATS! ON YOUR LOOP!
