I have a question on the throttle servo...would it be safe to move it closer to the engine? I'm using a BME 50 with CH Ignition. I've read that with CH Ignition, it would be better to have better separation between the radio components and the ignition. It seems with DA, you can mount some of your components closer.
I don't know where you heard that but its not accurate. The CH ignition is just a good as the DA. Put your throttle servo where you want or need it, and more than likely you will not have a problem. If you do its usually not a problem moving a servo around. I always install my radio gear where I want it to go, and sometimes that puts engine and radio components right next to each other. And I have never had any problems. How you install your gear is more important than where. Good luck!
