RCU Forums - View Single Post - BME Edge?
Thread: BME Edge?
Old 01-24-2005 | 05:51 PM
  #452
ed42d-RCU
My Feedback: (13)
Default RE: BME Edge?
ORIGINAL: desertpig
I was looking at the CH horns... they don't look like enough for 3D throws... they are nice though. I used the Rocket city horns and mine are nearly 1.5 tall to get the right displacement (45%).. I don't see the hyde horns getting anywhere close to that. The pics above show about 30% max..
As far as locating the equipment.. mine is all jammed into the nose on the firewall. The ignition, Li-Ion battery and regulator are all touching, the RX battery pack is 4" away from the Ign "bundle" and the throttle servo is mounted on the firewall 1" from the carb. The RX (PCMR770 JR) is less than 6" from all the rest of the stuff.
I went to a smaller (18oz) tank, elevated the tank and moved the Pull-Pull setup under it, so now that pull pull is as far forward as it can get and the tank is still nearly on CG.
I have perfect range and no issues in flight. My CG is 5.00 inches and my weight is 16 pounds 5 oz WET.
DP
DP...I hope you weren't referring to my bad pics. I just hooked them up to get a quick pic. Here's a better pic showing full deflection using the CH horns.
ID:	220113   Click image for larger version
