RE: BME Edge?
Good pics! I am glad to see the CH horns worked out... I was little worried...
Maudib - No doubt about needing shorter arms for longer throws.. for whatever reason the rocket city horns definitely need to be taller to achieve the 45* displacement... It would be easy for me to convert to the CH horns and I still might. That should be worth another ounce in the tail... !
Sparhawk - you will definitely be doing some surgery on that cowl. Don't worry though - it is heavy so cutting it away saves weight. I cut almost the entire bottom out of mine, and then mounted 2 small wood blocks with screws to support it from flapping on the bottom. This is good for the DA air supply, good for weight, and you don't even really see it. You want a lot more air coming out than going in..
I will try to take a picture tonight and post it here.
DP
