exocet gear
i use spring air retracts and selfmade duro struts.
wing joint reinforced with a plywood spar
for each elevator one servo beside the turbine mounted to the fuselage
you will need all the weight in the nose
the fuselage hatch build as an additional airbrake (not necessary for long runways)
mec
