exocet gear
FL
I am getting ready to start on an exocet. I would appreciate any information regarding this kit. I am in the process of getting everything together. I would like to know what gear I can use. I know there are several people flying this jet. It would be great to know what gear you have. Thanks. Alex.
i use spring air retracts and selfmade duro struts.
wing joint reinforced with a plywood spar
for each elevator one servo beside the turbine mounted to the fuselage
you will need all the weight in the nose
the fuselage hatch build as an additional airbrake (not necessary for long runways)
mec
mec
