RCU Forums - View Single Post - Flair Puppeteer Trust Angles
Old 01-25-2005 | 08:35 AM
bassman
Default Flair Puppeteer Trust Angles
Hi there. I just started building a Flair Puppeteer. Right off the bat I ran into an issue. When you build the tank box there are built in right and down thrust angles (even the plans say that's why the front of the box is angled). But when you build the fuselage frame there is no angle to the front where the firewall mounts. What is the proper assembly sequence. Do you glue the tank box to the fire wall, then install the assembly and sand the front of the fuselage to match the angles? This would be a pain. Or are the angles on the tank box for another purpose? The plans are not clear on this.
