Yellow Aircraft
The fin is a bit odd in that it has a vertical piece of wood that goes up the back of the fin that the hinges go into.
The ailerons and elevator are NOT double beveled but the rudder is. I don't have any picts showing max throws but it should be enough to 3D.
You can see the fin in the following pict which was taken after everything was removed from the box.
