Yellow Aircraft
Here is a better shot of the tail after I epoxied the horizonal fin down. The piece of wood on top pull out futher to glue down from the back of that former to the vertical piece of wood that goBTW, it's kind of a royal blue. Monokote goes up from the tail. You can see the "slot" where that vertical piece goes.
I built up behind the stabilzer a bit otherwise there is a gap.
