RE: pull start and gears
Dear Arizona Jay:
Sorry about the late reponse. Go ahead and give us a call at 714-792-1923 and we will take care of you from there. Sometimes the spur gears strips out due to motor/gears movement especially during jumps . In either case, we can send you a pull start under warranty and the pinion gears you broke. Please make sure you put on enough threadlock when you install them
If you wish to switch to roto-tech starter, the part number you will need is G70358 which include the roto-tech unit, backplate for NX76 and all hardwares. Please visit your LHS to order your.
