RE: my first rc plane?
your right in one sense , without some engine knowlege, starting &running glow can be confusing, however without some close attention electric can be disapointing and expensive. if with glow you hook your fuel lines up wrong , it simply wont run properly or start. with electric if you install your speed control back wards it will burn out instantly. electric will give consistent results once every thing is set up properly.
