RE: Flair Puppeteer Trust Angles
It builds well. (now that I have learn to trust the instructions). Mounting the four stroke wasn't too bad but it deffinetly was easier to do before the front of the fues was sheeted. I also installed the thortle push rod system before I closed up the front end. Did you install the alerion push rod/ belcrank system Flair supplies? I plan on installing seperate servos outboard in the wings. Did you install the pull pull system they suggest or go with the standard push rod system? I am leaning towared the standard push rod system. I installed a Magnum 52 four stroke. I hope it's enough engine. If not Magnum makes a 61 that the same size. All the reviews I have been able to read say the 52 should be plenty. I just emailed OS and told them they should make a four stroke that has the carb out the side of the engine (opposite the muffler) instead of the back. Most of my planes have plenty of side room in the cowl. The supplied fuel tank is a tight fit in the tank box leaving no room for padding. Was yours that way?
And the most important question, how does she fly??
