ORIGINAL: tpc3
I have a Hanger ( P51 1.50) that I have been working on and have installed an RCS 180 with front carburetor. But I have been stumped by how to install and connect the choke linkages.
I have been considering the use of a bell crank with one end connected to the choke and the other just a rod coming through the bottom of the cowl. I am using a JR6102 (6ch)
Has any one used this engine / plane if so how did it connect?
My H9 Extra uses a bellcrank to work the choke. It's a ZDZ 80 with the carb in the rear, any standard servo would do the job.
