RE: Throttle Push Rod Connection........
While we're on the subject....
I want to hang a Hitec H-55 servo from the engine mount using a bracket made from aluminum.
Thunder Tigre "25", under cowl, Global T6 ARF.
Will the alum. bracket draw enough heat to loosen the adhesive, or any other problems?? I've used the "'ole throttle servo at the engine compartment" trick before, but have been able to mount to firewall.
Thanks!!
Al
