RCU Forums - View Single Post - Throttle Push Rod Connection........
Old 01-27-2005 | 11:19 PM
Richard L.'s Avatar
Richard L.
My Feedback: (24)
Default RE: Throttle Push Rod Connection........
Here are two pictures showing the path of the flex cable inside the fuselage. Make sure the end of the cable at the throttle servo is at the same level as the EZ connector on the servo arm. Even though the path is not straight, the braided cable still moves freely with very little effort, just like the braided cables inside your bicycle brake lines.
ID:	221550   Click image for larger version
