RCU Forums - View Single Post - Unsolvable problem...
Old 01-28-2005 | 09:49 AM
SKYLINE350GT
Default RE: Unsolvable problem...
Did you clean the air filter? Are you using fresh fuel? Are all your fuel lines intact? Does your fuel tank have a leak? Is your exhaust lined up properly at the gaskets and not leaking? Did you try leaning the LSN? Did you check your clutch bell bearings or shoes?
