RCU Forums - View Single Post - Prospark Saito 150 Conversion
Old 01-28-2005 | 10:53 AM
alfa156's Avatar
alfa156
Default RE: Prospark Saito 150 Conversion
ORIGINAL: tkg
How are you making the Walbro carb pump work??
Hi
Are there many steps to make the walbro carb work?
The carb I've seems very simple. Fuel line in, L and H needle .........
Also, I installed a big 3W stack ... just in case.
Very keen to run the engine in pusher form .... with the air ramming into the velocity stack.
Wonder how much more power can I liberate from the ram air charging?
Or would the ram air cause problems?
