RCU Forums - View Single Post - Throttle Push Rod Connection........
Old 01-28-2005 | 12:56 PM
jzinckgra's Avatar
jzinckgra
Default RE: Throttle Push Rod Connection........
Here is a picture showing the same end of a Dubro flex cable after silver solder is applied:
i just crimp the metal clevis onto the wire with a pair of pliers, then make adjustments on the other end nearest the servo. I never trust my soldering and worry that the vibration may weaken the joint, hence the crimping.
