ORIGINAL: lettucelord
I got a ikarus shock edge 540, and i have no idea on how to install my axi engine. Can you send me any ideas or anything, cause im lost.l In the manual, it shows a diff engine, help. If you want to know the engine type just go to this link
http://www.hobby-lobby.com/brushless-axi2208.htm
thanks so much
alright, you are going to need to buy the radial mount for your motor, you can get it from hobby lobby. then, glue the plastic x shaped thing that comes with the shockflyer kit with some foam CA. now you are going to need a small piece of 1/8 inch light plywood cut into a diamond just big enought to fully cover the plastic "motor mount". then epoxy this wood "firewall" to the plastic motor mount and screw your radial mount for your axi to the wood.
kinda hard to explain, but i hope you get the point, it takes some immaginatoin...ill give ya a quike sketch to show ya what im talkin about...
**edit** ....or you could just do what the link he gave you says to do....^^^^
