If you has own lathe or your friend has a lathe, you can make own 1/4-32 tap of drill rod (some time called for silver steel) or carbon steel and hardening the tap before use.
See in article about make own tap:
http://easyweb.easynet.co.uk/~chrish/homepage.htm see after the list: 7. Make a tap and die from carbon steel.
I has maked 2 tap and works well as original tap.
Jens Eirik
