Reed valve issue on Ryobi 31cc
Does any one know if the stock reed valve should sit flat on the carb spacer and be sealed or does it have a slight curve inward to produce nore retun spring pressure. I opened up my ryobi and the reed valve has a slight bend inward toward the crank that I can see light under. I am having trouble with this engine not running unless its on full choke. I thinks its a carb issure but found the "warped" reed valve and did not know.
Thanks for any help.
Joe Mc
Ultra Lite 120
