RCU Forums - View Single Post - R/C Nobler Topflite Gold Edition
Old 01-30-2005 | 09:42 AM
  #41
jimcork1
Default RE: R/C Nobler Topflite Gold Edition
You're right the belly pan is.. [:'(]
Just make sure you put the sides on while it is on the fuselage so you can get a good line up. Mine fits well after much [:@]
I have completed covering the wing, fuse stab and rudder. I still need to attach the rudder. If I finish today I will add pics of the bird.
The servos linkage is not installed yet.
Covering the belly pan was [:'(], but finally finished it. [&:]
I havent' even thought about the cowl or the remote glow lighter yet.
I haven' t check cg since I started adding parts. Hopefully moving the battery will get the cg right. I am using a good running La .46.
Last check weight minus engine, spinner cowl and rec was 3 3/4#'s.
Jim
