RE: CG and Control Throws
feihu,
Your drawing is almost spot-on!! My fuse is actually 6-3/4 at the leading edge of the wing.
At the 4" spot aft of the leading edge the plane "almost" balances I might need 1-2 oz. more weight in the nose. As far as angles of control throws I will use you measurements and re-adjust accoring to angle, not inches. I'll get a protractor and get the proper angle.
Thanks again for your posts!! I'll be back!!
