RCU Forums - View Single Post - Wing Bolting Question
Old 01-30-2005 | 07:25 PM
smedsky
Default RE: Wing Bolting Question
Usually a 1/4 inch dowell is installed, in the wing, 90 deg. to the leading edge in the center extending about 5/16. Then a structure, attached to the fuselage, needs to be made for it, to extend into, usually plywood with a 1/4 inch hole in the center. If this is confusing enough, then procede.
