Brian Taylor Hellcat
I asked the following questions in the Warbird forum and did not receive one answer so I will try here.
Has anyone built and/or flown the Brian Taylor 64" Hellcat? What retracts did you use? Will the Robart 615s work? Did you add flaps? Did you use the fiberglass fuse? How was the fiberglass fuse? Is the outline of the fiberglass fuse scale or is it off? Did it need much prep work? What engine did you use? How much did it weigh? How much scale detail did you put into it? Where did you get the scale documentation (three views)? How did it fly? How was the slow speed handling? How was it on the landing approach? Any information would be greatly appreciated.
