ORIGINAL: Fletch124
I have connected the battery to the ESC as the instructions say, black wire to black wire, Red wire to Red wire, I attached them together with alittle plastic thing in an electical kit that i have that you put both ends in and it has a peice of metal in the middle so know what it does, Then you crimp it so the wires don't go anywere, Is this a good idea???
Am i doing anything wrong???
Should i have a switch on this airplane of not???
How do you disconnect the battery to charge it if it is crimped to the ESC??
If I understand all this right then you are not correct. The batteries need to be disconnected from the ESC to be charged in all the chargers I have seen.
A picture may help me understand what is going on.
