RE: Remove loctite
why can't you remove engine from car..... Are those screws stuck also? An easy out is a hardened reverse threaded rod with a point.. kind of like a drill bit in reverse... you tap it onto the bolt and turn it counter-clockwise... it digs into the screw head while removing it ... works great as long as the screw isn't too soft....
