Great
For all those interested in the bladerunner and modifications for it, here are some links to some very long threads on rcgroups containing a wealth of info about it (including posts by the guy who invented it):
http://www.rcgroups.com/forums/showthread.php?t=279923
http://www.rcgroups.com/forums/showthread.php?t=294497
http://www.rcgroups.com/forums/showthread.php?t=318262
and here is a document that contains a lot of information collected from those threads:
http://theclassroom.50megs.com/Blad...Information.doc
OR
http://theclassroom.50megs.com/Blad...Information.pdf
ORIGINAL: Greg Covey
Roq,
Thanks for the links and feel free to post them here as well.
I discovered that if I remove the heatshrink on the tail boom end and cut away the tail blade ring that I have much improved forward and reverse authority. I can fly circuits around my living room now and get away from hazzards like furnace heat air flow.
I will look at the links to see what folks are replacing the Lithium cell with. Since I seem to have plenty of thrust, a slightly heavier cell with more duration should work fine.
