RCU Forums - View Single Post - Variable CG?
Thread: Variable CG?
Old 02-01-2005 | 06:00 PM
Redback's Avatar
Redback
Default RE: Variable CG?
Just played around with some numbers:
Seems to me that for a plane in the 5 - 6 lb region a 1 oz weight would need to move a long way to make any significant difference to the CG.
The mechanism needed to move the weight would be a significant penalty also. Best way is probably to fit two fuel tanks and pump fuel around. Problem when you run out of ballast though!
Terry
