Any interference installing throttle servo by zenoah g26?
Pretttyy much what the thread says.
What I have done is install a hitec hs422 standard servo in the firewall. its right behind the walbro carb. The reason I did this because i found it to be a bitttt more difficult installing to the middle of the fuse. If interference does occur, what methods can be used to prevent interference? the push rod is 4-40 thread and metal dubro 4-40 clevises.
Have a good night fellas!
